[Qgis-user] Problem compiling 0.8 on SUSE 10.2 64bits
Hernán De Angelis
dhdeangelis.listas at gmail.com
Sun Feb 18 08:46:04 EST 2007
Sergio,
The configure script is complaining about not finding the header
files, in particular those from the GDAL/OGR library. May be the RPMS
you used are not complete, i.e. like they do not include the "devel"
packages. In my opinion it is almost always better to compile from
source.
Saludos y suerte
Hernán
2007/2/18, Jean Cayron <jean.cayron at gmail.com>:
> Hy sergio,
> I installed also the RPM depedencies form the same source. I didn't have the
> georeferencer ok with configure. I tried so many way that maybe one left
> something that helped me to go through finally.
> I cannot really help you more (it was the very first time that I succeded a
> compilation since I was born...)
> I tried first to install the 62bits RPM but all the dependencies weren't
> installable on 64bits (some 32bits libs had the same name than the 64bits
> one).
> So, "courage"
> Jean
> 2007/2/17, Sergio López <sergiodlopez at yahoo.com>:
> > Hi Jean,
> > I've followed your instructions and everything went well with ./configure,
> receiving the output you can find below. But when I make, I receive the
> following error:
> > In file included from ../gui/qgscoordinatetransform.h:28,
> > from ../gui/qgsmaplayer.h:33,
> > from qgsdatamanager.cpp:19:
> > ../gui/qgsspatialrefsys.h:20:21: error: ogr_api.h: No
> such file or directory
> > ../gui/qgsspatialrefsys.h:21:28: error: ogr_spatialref.h:
> No such file or directory
> > ../gui/qgsspatialrefsys.h:22:23: error: cpl_error.h: No
> > ../gui/qgsspatialrefsys.h:207: error: 'OGRSpatialReference' does not name
> a type
> > make[4]: *** [libqgis_core_la-qgsdatamanager.lo ] Error 1
> > I have installed QGIS dependencies using RPMs. can that be the cause of
> such error? should I use sources?
> > Sergio
> > ./configure output:
> > qgis 0.8.0
> > GDAL/OGR : yes (Version 1.3.2)
> > GEOS : yes (Version 2.2.3)
> > PostgreSQL : yes (Version 8.1.3)
> > GRASS : yes
> > SPIT : yes
> > Georeferencer : yes
> > WFS : yes
> > GPS/GPX : yes
> > PROJ4 : yes
> > SQLITE3 : yes
> > Python :
> > CPPFLAGS : -I/usr/include
> > CXXFLAGS : -g -O2
> > Debug : no
> > Plugin dir : /usr/lib/qgis
> > The binary will be installed in /usr/bin
> > The build is using Qt in /usr/lib64/qt4
> > Linking with Qt using -lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtSvg
> -lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtXml -lQtSvg -lQtTest
> -lQtDesigner
> > ----- Mensaje original ----
> > De: Jean Cayron <jean.cayron at gmail.com>
> > Para: Sergio López < sergiodlopez at yahoo.com>
> > CC: qgis-user at lists.qgis.org
> > Enviado: sábado 10 de febrero de 2007, 10:37:20
> > Asunto: Re: [Qgis-user] Problem compiling 0.8 on SUSE 10.2 64bits
> > Sorry,
> > I wasn't complete in my last post. I finally went through and I can now
> use Qgis on openSuse 10. x86_64.
> > The way :
> > su
> > ln -s /usr/include /usr/lib64/qt4/include
> > ln -s /usr/bin /usr/lib64/qt4/bin
> > ls -s /usr/lib64 /usr/lib64/lib
> > exit
> > ./configure --with-qtdir=/usr/lib64/qt4 --with-sqlite3dir=/usr
> --with-grass=/usr/grass-6.2.1 --with-postgresql=/usr/bin --with-python
> > make
> > su
> > make install
> > cp /usr/lib/libqgis_gui.so.1 /usr/lib64/qt4/
> > exit
> > and it should work...
> > Jean
> > 2007/2/10, Jean Cayron < jean.cayron at gmail.com >:Hello,
> > I had the same problem.
> > I resolved the problem of lib lib64 moc etc. by doing this (as su) :
> > Then I made make and make install. But I get other errors like these :
> > make[5]: Rien à faire pour « install-exec-am ».
> > make[5]: Rien à faire pour « install-data-am ».
> > When I tried the commande qgis it said :
> > > qgis
> > qgis: error while loading shared libraries: libqgis_gui.so.1: cannot open
> shared object file: No such file or directory
> > If you manage to make a rpm or have a good method, please, inform us...
> It's days I'm trying.
> > Jean
> > 2007/2/9, Sergio López < sergiodlopez at yahoo.com >: I'm trying to compile
> qgis 0.8 from source with grass support on a SUSE 10.2 64bits box, but I
> bumped into a problem with the QT4 libraries.
> > I can't find a solution to the with-qtdir parameter, because my libraries
> are located in /usr/lib64/qt4 but there's no "include" directory there.
> > I found a solution in here
> http://www.nabble.com/Problems-compiling-qgis-0.8.0-tf3083766.html#a8599051
> > but when I ./configure I receive the following error:
> > checking QTDIR... /usr/lib64/qt4
> > checking Qt version in /usr/lib64/qt4/include/Qt... 421 (4)
> > checking for moc... no
> > configure: error: *** moc must be in path
> > by the way moc is located in /usr/bin, which IS already in path :
> > echo $PATH
> /home/sergio/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin..etc
> > Can anyone tell me how to solve this issue please?
> > Thanks in advance.
> > Sergio
> > __________________________________________________
> > Preguntá. Respondé. Descubrí.
> > Todo lo que querías saber, y lo que ni imaginabas,
> > está en Yahoo! Respuestas (Beta).
> > ¡Probalo ya!
> > http://www.yahoo.com.ar/respuestas
> > Qgis-user mailing list
> > Qgis-user at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
> > ¡Probalo ya!
Hernán De Angelis
Linux user # 397217
