[Qgis-user] help building QGIS 0.8.1 on Ubuntu Dapper
Tim Sutton tim at linfiniti.com
Fri Jul 20 18:55:21 EDT 2007
Hi Reid
The instructions for building QGIS from source are supplied in the
sources as INSTALL.txt. In 0.8.1 we started a new system for
providing INSTALL.txt. Before this the install process was described
in various places on our wiki. We updated the install docs regularly
on the wiki but this meant the docs became incorrect for older
versions of QGIS. With the new approach the INSTALL.t2t doc is now
under version control and so we can provide backtrackable install
notes for all releases of QGIS. However due to an oversight, a part
of the linux install notes were ommitted. This will be repaired in
the upcoming release of QGIS.
Regarding automake support, the only practical way to continue suport
for it is if someone volunteers to update the automake build system
to work with the new python bindings, refactored libs etc. Any
volunteers?
Best regards
Tim
Em 20/07/2007, às 14:07, Reid Priedhorsky escreveu:
> Aaron Racicot wrote:
>> Well, can you post the build output so we can look and make sure
>> there is
>> nothing suspicious there?  Also, can you run ldd on the core.so
>> file...
>> something like:
>> aaronr at z-linux2: ldd /usr/local/lib/libqgis_core.so
>>         linux-gate.so.1 =>  (0xffffe000)
>>         libQtCore.so.4 => /usr/lib/libQtCore.so.4 (0xb7bec000)
>> Is there anything in the ldd dump of the .so that showed errors or
>> other
>> .so's it can't find?  Shooting a bit in the dark here as I have
>> not seen
>> that error, but it is having trouble resolving the symbol in a
>> shared object
>> at run time... ldd might provide a hint.
> Aaron,
> An excellent suggestion -- it turns out that it was finding the QT
> libraries included with the system, not the ones I had compiled
> against.
> "export
> LD_LIBRARY_PATH=/export/scratch/reid/qt-4.2.2/lib:$LD_LIBRARY_PATH"
> did
> the trick. QGIS now starts up, though I haven't yet tested it in
> detail.
> I wonder if this is something that could be fixed in the build
> process?
> I've compiled a lot of software in the past that used libraries other
> than the ones installed by the system, including QGIS 0.8.0 using
> autotools configure, and they didn't need LD_LIBRARY_PATH juju to run.
> In a larger sense, from the perspective of users like me who are
> compiling QGIS from source on UNIX, the new build system is a major
> regression from the old autotools system. In 0.8.0, it was ./configure
> --with-qtdir=FOO; make; make install ... poof! working QGIS. With
> 0.8.1
> it was no installation instructions that applied to me, scouring
> mailing
> lists (including for basic stuff like how to specify which QT
> install to
> use), asking for help on mailing lists, compiling and installing cmake
> since the one on my system was too old, etc., etc. Ugh.
> I don't know if I get a vote in the discussion of whether to remove
> autotools configure from 0.9, but if I do, I vote -1.
> Thanks,
> Reid
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20070720/96cb61a9/attachment.html
