[Qgis-user] Help Needed - Building qgis with Postgres
Elavazhagan.M elavazhagan.mouniandy at kcubeconsulting.com
Mon May 21 07:01:00 EDT 2007
I am trying to configure qgis with PostGreSQL-8.1.9 support using the
following command:
./configure \
--with-qtdir=/usr/local/Trolltech/Qt-4.2.3 \
--prefix=/usr/local/qgis \
--with-gdal=/usr/local/bin/gdal-config \
--with-postgresql=/usr/local/pgsql/bin/pg_config \
--with-geos=/usr/local/bin/geos-config \
--with-sqlite3dir=/usr/local \
--with-grass=/usr/local/grass-6.2.1
As mentioned in the above command, I have installed all the required
libraries in those locations only. But, the result of the command is
like the following with no version information of PostGreSQL.
qgis 0.8.0
GDAL/OGR      : yes (Version 1.4.1)
GEOS          : yes (Version 2.2.3)
PostgreSQL    : yes (Version )
GRASS         : yes
SPIT          : yes
Georeferencer : no
WFS           : no
GPS/GPX       : yes
PROJ4         : yes
SQLITE3       : yes
Python        : no
CPPFLAGS      :  -I/usr/local/include
CXXFLAGS      : -g -O2
Debug         : no
Plugin dir    : /usr/local/qgis/lib/qgis
The binary will be installed in /usr/local/qgis/bin
The build is using Qt in /usr/local/Trolltech/Qt-4.2.3
Linking with Qt using -lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtSvg
-lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtXml -lQtSvg -lQtTest
-lQtDesigner
Configure finished, type 'make' to build.
After configuring with the above command, when I run 'make' it gives me
the following error:
creating libqgis_core.la
(cd .libs && rm -f libqgis_core.la && ln -s ../libqgis_core.la
libqgis_core.la)
make[4]: Leaving directory
`/root/gis/downloads/qgis/qgis-0.8.0/src/core'
make[3]: Leaving directory
Making all in ui
make[3]: Entering directory `/root/gis/downloads/qgis/qgis-0.8.0/src/ui'
make[3]: *** No rule to make target `ui_qgisappbase.h', needed by `all'.
Stop.
make[3]: Leaving directory `/root/gis/downloads/qgis/qgis-0.8.0/src/ui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/gis/downloads/qgis/qgis-0.8.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/gis/downloads/qgis/qgis-0.8.0'
make: *** [all] Error 2
Do anyone know what are the possible causes for this error? (I'm facing
this build error only when I include PostGreSQL support.)
Kindly help me out to resolve this issue.
Thanks.
Regards,
Ela.
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20070521/c61d27d7/attachment.html
