[Qgis-user] Help Needed - Building qgis with Postgres
Elavazhagan.M
elavazhagan.mouniandy at kcubeconsulting.com
Mon May 21 07:58:40 EDT 2007
If we specify the full path to the PostGreSql along with the file name
(pg_config), it doesn't compile.
But specifying only the path to pg_config compiles. The
following ./configure command worked fine for me:
./configure --with-qtdir=/usr/local/Trolltech/Qt-4.2.3
--prefix=/usr/local/qgis --with-gdal=/usr/local/bin/gdal-config
--with-postgresql=/usr/local/pgsql/bin
--with-geos=/usr/local/bin/geos-config --with-sqlite3dir=/usr/local
--with-grass=/usr/local/grass-6.2.1
Thanks.
Regards,
Ela.
On Mon, 2007-05-21 at 16:31 +0530, Elavazhagan.M wrote:
> Hi,
> I am trying to configure qgis with PostGreSQL-8.1.9 support using the
> following command:
> ./configure \
> --with-qtdir=/usr/local/Trolltech/Qt-4.2.3 \
> --prefix=/usr/local/qgis \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-postgresql=/usr/local/pgsql/bin/pg_config \
> --with-geos=/usr/local/bin/geos-config \
> --with-sqlite3dir=/usr/local \
> As mentioned in the above command, I have installed all the required
> libraries in those locations only. But, the result of the command is
> like the following with no version information of PostGreSQL.
> qgis 0.8.0
> GDAL/OGR : yes (Version 1.4.1)
> GEOS : yes (Version 2.2.3)
> PostgreSQL : yes (Version )
> GRASS : yes
> SPIT : yes
> Georeferencer : no
> WFS : no
> GPS/GPX : yes
> PROJ4 : yes
> SQLITE3 : yes
> Python : no
> CPPFLAGS : -I/usr/local/include
> CXXFLAGS : -g -O2
> Debug : no
> Plugin dir : /usr/local/qgis/lib/qgis
> The binary will be installed in /usr/local/qgis/bin
> The build is using Qt in /usr/local/Trolltech/Qt-4.2.3
> Linking with Qt using -lQtCore -lQt3Support -lQtGui -lQtNetwork
> -lQtSvg -lQtCore -lQt3Support -lQtGui -lQtNetwork -lQtXml -lQtSvg
> -lQtTest -lQtDesigner
> Configure finished, type 'make' to build.
> After configuring with the above command, when I run 'make' it gives
> me the following error:
> creating libqgis_core.la
> (cd .libs && rm -f libqgis_core.la && ln -s ../libqgis_core.la
> libqgis_core.la)
> make[4]: Leaving directory
> `/root/gis/downloads/qgis/qgis-0.8.0/src/core'
> make[3]: Leaving directory
> Making all in ui
> make[3]: Entering directory
> `/root/gis/downloads/qgis/qgis-0.8.0/src/ui'
> make[3]: *** No rule to make target `ui_qgisappbase.h', needed by
> `all'. Stop.
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/root/gis/downloads/qgis/qgis-0.8.0/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/root/gis/downloads/qgis/qgis-0.8.0'
> make: *** [all] Error 2
> Do anyone know what are the possible causes for this error? (I'm
> facing this build error only when I include PostGreSQL support.)
> Kindly help me out to resolve this issue.
> Thanks.
> Regards,
> Ela.
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20070521/900d3503/attachment.html
