[Qgis-user] creating hillshades
maning sambale
emmanuel.sambale at gmail.com
Fri Nov 16 06:54:57 EST 2007
nishith,
Check the range of values of your SRTM raster (usually between
+-32769). You should probably need to limit the range of your map.
r.mapcalc ?
maning
On 11/16/07, nishith datta <nkdiitd2002 at yahoo.com> wrote:
> hi all,
> I am using Qgis 0.9.0 Ganymede in windows.
> I have downloaded a srtm geotiff dem from usgs glcf site.
> I want to create a hillshade map from it. I tried using the grass plugin.
> I imported the srtm into grass mapset as a raster ( used r.in.srtm)
> Then I used r.shaded.relief but it creates an empty raster.
> Can someone help me out ?!?!
> Thanks
> nishith
> Never miss a thing. Make Yahoo your homepage.
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI |http://www.geocities.com/esambale/philbiodivmap/philbirds.html |
