[Qgis-user] creating hillshades
Maciej Sieczka
tutey at o2.pl
Fri Nov 16 09:20:39 EST 2007
maning sambale wrote:
> nishith,
> Check the range of values of your SRTM raster (usually between
> +-32769). You should probably need to limit the range of your map.
Are you sure you have set your region to match your SRTM
tile's extent first? See g.region manual.
GRASS specific questions are better asked at GRASS user
mailing list. And don't forget to search in archives before
asking a question.
Maciek
