[Qgis-user] troubles with the interpolation of point data
Maciej Sieczka tutey at o2.pl
Thu Nov 29 12:33:05 EST 2007
> On Thu, 29 Nov 2007 10:18:02 +0000
> serafin fages <pepefagich at hotmail.com> wrote:
>> thanks for all you help.
>> I have been having troubles with the interpolation of a piont file (grass
>> format). I have to choose an attribute in the window of the grass module and
>> for some reason it does not allow me to choose from the drop down. When I look
>> at the atribute table, the attribute field exist. The same thing hapens when
>> I try to do anything where I have to choose an arttibute from the field drop
>> down in a the grass module.
Are you on Windows? I once tried v.to.db from GRASS Toolbox
on Windows and I had the same issue - could not select a
datatable column to be populated, although the table was
allright.
Maciek
