[Qgis-user] coordinates in both projected and geographic systems
John C. Tull
john.tull at wildnevada.org
Wed Aug 6 11:42:39 EDT 2008
This is a nice plugin/addition.
One possible issue I encountered: if you close the coordinate window
(if floating) or the view in the toolbar, how can you get the window
or toolbar view back without an application restart? Intuitively,
hitting the plugin icon or selecting it from the plugin menu should do
a check to see if the floating window or toolbar/legend view is
present and reinitiate as required.
Thanks,
John
On Aug 6, 2008, at 7:27 AM, Tim Sutton wrote:
> Hi
> I wrote a little plugin that lets you click on the map and copy the
> coordinates to the clipboard. If you are using on the fly projection
> it will display coordinates both in lat/lon and in the map canvas
> projection.
> http://www.flickr.com/photos/timlinux/2738766800/
> http://www.flickr.com/photos/timlinux/2738766796/
> Probably doesnt address all the needs expressed in this thread but
> hopefully it will take you some way there. Plugin is in SVN trunk and
> will be in QGIS 1.0.0
> Regards
> Tim
> 2008/8/4 Tim Sutton <tim at linfiniti.com>:
>> Hi
>> Both use cases are technically not difficult I think - its just a
>> matter of someone finding the time amongst all the other things that
>> need sorting out for QGIS 1.0. Be sure to file a feature /
>> enhancement
>> request and we will get to this when time permits.
>> Regards
>> Tim
>> 2008/7/31 Michael Neubauer <Neubauer-Michael at gmx.net>:
>>> Actually, I was thinking about a similar problem:
>>> I am working in an area, where two different projections are used
>>> (UTM and
>>> S42). So I get locations in both coordinate systems and I would
>>> like to
>>> display them at the same time on the map.
>>> So I have the same wish as Austin, only that I would like to have
>>> two
>>> different projected systems displayed.
>>> Maybe it is already possible...?
>>> Thank you very much for thinking about it.
>>> micha
>>> Am Mittwoch 30 Juli 2008 18:06:31 schrieb Agustin Lobo:
>>>> Could it be possible in the future having the
>>>> coordinates displayed both in the projection system
>>>> of the project (as it is now ) and as geographic
>>>> (lon, lat) coordinates? For example, today I was
>>>> using my data in qgis as an aid to search the spot
>>>> catalogue, where you define windows as lat, lon.
>>>> Having had both types of coordinates would been
>>>> helpful.
>>>> Thanks!
>>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton
>> QGIS Project Steering Committee Member - Release Manager
>> Visit http://qgis.org for a great open source GIS
>> Blog: http://tim.linfiniti.com
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Tim Sutton
> Skype: timlinux
