[Qgis-user] QGIS looses toolbar icons after
changing background color
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Aug 17 21:10:51 EDT 2008
On Sun, 2008-08-17 at 18:02 -0700, Alex Mandel wrote:
> Nikos Alexandris wrote:
> > On Mon, 2008-08-18 at 03:22 +0300, Nikos Alexandris wrote:
> >> On Mon, 2008-08-18 at 03:16 +0300, Nikos Alexandris wrote:
> >>>>> Dear QGIS-users and developers,
> >>>>> I 've come across this strange behaviour: Settings > Background Color
> >>>>> (change color to anything) > OK. The result is that all toolbar icons
> >>>>> disappear, only text is shown for each button!
> >>>>> QGIS 0.11.0-Metis under Ubuntu Hardy 64-bit (with GRASS 6.4.svn)
> >>>>> Kind regards, Nikos
> >>>> Did you change it in Project or Options?
> >>> Sorry, I missed that here. Please read below.
> >>>> Was a Grass Mapset loaded?
> >>>> Did you have vector layers loaded?
> >>>> Raster layers?
> >>>> I tried a simple test but wasn't able to repeat it yet.
> >>>> Alex
> >>> 1. Launch qgis from within grass-6.4.svn (moving to next action
> >>> immediately, that is no GRASS-plugin loaded at all, no vector/raster
> >>> layers loaded).
> >>> 2. Settings > Options > Background Color > change color > OK
> >>> Result: except digitizing toolbar all other icons are lost, only text
> >>> remain for each button.
> >> Quitting and re-launching qgis gives last selected background color with
> >> icons-buttons. Repeating steps 1,2 (above) (re)produces the error.
> > Ohh!! My "icon theme" is empty in the "Settings > Options" dialog!
> > What's up?
> Does anything change if you launch qgis directly, not from inside grass?
No. Problem remains.
> Alex
P.S. But I still did not take time to correct the following problem
which shouldn't be that difficult to fix.
(copy-paste from http://www.nabble.com/Re%
3A-grass6.4-develbrunch-revision-32726%
3A-undefined-reference-to-`G_no_gisinit'-td18947949.html)
Funny! Today I recompiled all osgeo packages on my Ubuntu-box (install
proj4, install geos, compile gdal_stable without GRASS support, compile
GRASS6.4.svn, compile gdal-grass-plugin, compile qgis_0_11_0). I
carefully linked properly to the "local" installed libraries while
configuring QGIS with ccmake.
Now, while I run QGIS from within GRASS and use GRASS tools without
problems, I can't even load the GRASS-plugin if I run QGIS outside of
the GRASS-shell.
The error message is:
qgis: symbol lookup error: /usr/local/lib/libqgisgrass.so.1.0:
undefined
symbol: G__no_gisinit
