[Qgis-user] dependencies on OpenSuSE 11.1 KDE4
pcreso at pcreso.com pcreso at pcreso.com
Mon Dec 29 20:07:56 PST 2008
 Hi Gian,
 For OpenSuse installs of GIS/GPS related applications I
 suggest you install the GEO repositiory using YAST.
 Once this is done, you should be able to oinstall QGIS
 & many other useful apps with no dependency problems (at
 laeast it worked very well for me with 10.2, 10.3 &
 11.0, I haven't yet tried 11.1, but plan to get around
 to it shortly :-)
 If you have installed packages from elsewhere, you may have
 some version conflicts, this repo tends to have pretty
 current versions of most apps.
 http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
 It also has packages for other distros, including Mandriva
 & Fedora, in particular.
 Cheers,
   Brent wood
 --- On Tue, 12/30/08, G. Paolo Sanino V.
 <research at leviathanchile.org> wrote:
 > From: G. Paolo Sanino V. <research at leviathanchile.org>
 > Subject: [Qgis-user] dependencies on OpenSuSE 11.1 KDE4
 > To: qgis-user at lists.osgeo.org
 > Date: Tuesday, December 30, 2008, 12:36 PM
 > Hi,
 > I just moved to the new openSUSE 11.1 (x86_64) with KDE
 > 4.1.3.
 > Not that happy with the changes but too late to walk
 > back...
 > Under OS11.0 is was as simple as use Yast, search for Qgis
 > and thet getting it
 > installed. However, in 11.1 qgis does not shows up on the
 > defaults list of
 > application packages. Then after adding several
 > repositories it shows up at
 > "factory". As well as from www.opensuse.org, the
 > one clik utility worked fine
 > in finding qgis under OpenSuSE-Factory. However, using the
 > online tool or Yast
 > with the repositories, I cannot get QGIS installed due to
 > the missing:
 > libgeos-3.0.0.so()(64bit).
 > Looking at RPM find and other sites, I found two packages
 > that contain this
 > library but no way to install any of them, as they present
 > even more failed
 > dependencies during the attempts.
 > Is this happening to somebody else? if so, have you found a
 > workaround to get
 > qgis installed in this distro?
 > Thanks a lot! and congratulations for the great work on
 > QGIS.
 > Gian
 > Qgis-user mailing list
