[Qgis-user] (no subject)
John C. Tull john.tull at wildnevada.org
Tue Dec 30 19:02:31 PST 2008
Tom,
Have you tried building with the qt-4.5 beta that recently was
released? I'm trying with the binary from trolltech (have not tried a
source build yet), but seem to be hitting some issues with
international support (maybe the binary does not have that included;
it's not a big download). The grass plugin also appears to still be a
problem.
I'd like to hear how this might affect the mac platform (positive and
negative) and any workarounds that you are able to conjure. I posted
links to my build errors on irc a moment ago if you care to look at
them.
Regards,
John
On Oct 17, 2008, at 10:44 PM, Tom Elwertowski wrote:
> John C. Tull wrote:
>> On a side note, with Qt4.5 carbon built from today's snapshot, the
>> grass plugin fails to compile. I had to disable grass in order to
>> get a finished qgis trunk build. Because qt is not stable, I have
>> not filed a bug.
> qgsgrassshell is the one remaining QGIS module that still needs
> Qt3Support.
> Qt4.5 is supposed to enable Qt3Support for a Carbon-only build but
> disable it for a Cocoa or combined build. I have only done a
> combined build so I haven't built Qt4.5 Qt3Support.
> I use an unfinished port of qgsgrassshell. I have uploaded it to http://telwertowski.home.comcast.net/qgsgrassshell_qt4_r9490.diff
> One problem with this shell is that large blocks of output are not
> initially displayed correctly. Instead of multiple lines, you may
> see one line repeated multiple times. If you cover and uncover the
> window, the correct output will be visible. The shell also freezes
> after running a tool from the command line. The workaround is to
> close and reopen the shell. I suspended work on porting the shell to
> do the menu reorganization for QGIS 1.0.
> Tom
