[Qgis-user] Change of object type
José María Michia jose.maria.michia at gmail.com
Thu Dec 4 20:33:08 EST 2008
2008/12/4 Goyo <goyodiaz at gmail.com>:
> El jue, 04-12-2008 a las 18:29 +0100, Agustin Lobo escribió:
>> By some reason I've got a shp that should be a set of polygons, as lines.
>> Is it possible with QGIS to automatically define the polygons and save
>> the layer
>> with the correct vector type (polygons)?
>> Thanks
>> Agus
> I have done this before using the GRASS plugin. I don't remember the
> exact command.
If you can run GRASS commands,  you can build polygons with something like:
v.build map=map_of_lines option=build
Saludos
José María
> Goyo
> Qgis-user mailing list
