[Qgis-user] Select by attributes
Mats Elfström mats.elfstrom at gmail.com
Fri Dec 12 05:48:51 EST 2008
Hi!
What would be the simplest way to select elements by their geometric
attributes in QGIS?
In MapInfo, the SQL select string I need would look like this:
select * from TableName where Area(obj, "sq km") > .5
As a workaround, I could populate an 'area' column in the table, but I would
still need an Area() function to do that.
Please do not suggest compiling this and that library from hist and here
because this is a question from a vanilla QGIS user.
Other than that, any help is appreciated.
Regards, Mats.E
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20081212/41750c7e/attachment.html
