[Qgis-user] Display of selected polygon only
Agustin Lobo Agustin.Lobo at ija.csic.es
Thu Dec 18 10:24:48 EST 2008
The problem is that there ~2000 polygons,
many overlapping.
I think that highlighting should be independent of
the "no pen" and "no brush", best there should
be an independent setting to select type of lines and colors
for highlighted polygons. Opinions?
Agus
G. Allegri wrote:
> If the selection is based on an attribute you could symbolize the
> polygons with unique symbols, and set a different fill color for the
> (two? selected/unselected) classes of polygons.
> 2008/12/18 Agustin Lobo <aloboaleu at gmail.com>:
>> Hi!
>> I've made a set of polygons with R
>> (the bopundaries of images that
>> have been acquired with a small UAV)
>> and then saved as shp.
>> As the set is kind of crowed, when I display in Qgis, I would like
>> to display only the polygon(s) that
>> I have selected in the table, not even
>> the boundaries of the rest of polygons.
>> Is this possible? By now, if I select
>> "no pen" and "no brush", I get nothing
>> highlighted.
>> Thanks
>> Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> LLuis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> email: Agustin.Lobo at ija.csic.es
>> http://www.ija.csic.es/gt/obster
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
