[Qgis-user] Mapserver Export
Richard Duivenvoorde richard at duif.net
Thu Feb 14 12:31:41 PST 2008
Hi Jacolin,
what versions (both qgis and plugin) are you using? I know this was an
'old' error in the mapserver plugin of gary...
I just installed the plugin fresh via the python plugin installer in
qgis 9.2 here (ubuntu), and it's working. So I presume it is fixed and
you could try to load a new version of it?
(you can always download the plugin direct via:
http://spatialserver.net/pyqgis/plugins/mapserver_export.zip and unpack
it in ~/.qgis/python /plugins directory).
Grtz Richard Duivenvoorde
Jacolin Yves wrote:
> Hi,
> I have a problem with the mapserver export plugin, I get an error:
> self.dlg.ui.txtMapFilePath.text())
>  File "/home/yjacolin/.qgis//python/plugins/mapserver_export/ms_export.py",
> line 37, in __init__
>   self.qgs = minidom.parse("/home/gsherman/test1.qgs")
>  File "/usr/lib/python2.5/site-packages/_xmlplus/dom/minidom.py", line 1915,
> in parse
>   return expatbuilder.parse(file)
>  File "/usr/lib/python2.5/site-packages/_xmlplus/dom/expatbuilder.py", line
> 924, in parse
>   fp = open(file, 'rb')
> IOError: [Errno 2] Aucun fichier ou répertoire de ce
> type: '/home/gsherman/test1.qgs'
> Indeed, in my python file, l.37:
> How can I change this line to use the plugin ?
> Thanks,
> Y.
