[Qgis-user] wrong with "export to mapserver"
Richard Duivenvoorde rdmailings at duif.net
Tue Feb 26 12:00:43 PST 2008
Hi Orkun,
did you save your project as a qgs-project file first?
I tried the plugin with 9.1 here on windows, with a simple postgis layer
and it generated a mapfile.
First save the project with your postgis layers, and after that, export
this project to mapfile.
see screendump http://www.duif.net/qgis/mapserverexport1.jpg
and http://www.duif.net/qgis/mapserverexport2.jpg for the 'succes'-dialog.
Another option is to use the upcoming python plugin for that (you need
qgis 9.1 or higher to use the python plugins). After enabling 'Plugin
Installer'-plugin, you can get a list of current (python) plugins and
get it. It seems that there is a bug in it, and there are some other
things which can be refined (see this thread:
http://www.nabble.com/Mapserver-Export-to15454127.html). But if you can
write a few lines of python, it's a good start. You can find python
plugin hints in blog wiki or mailinglists.
Hopefully Gary will work on it any further (don't know his
plans/planning), or we must find a way in which other people can
continue working on other peoples plugins ...
Good luck
orkun wrote:
> hello
> I am trying to use "export to mapserver" a postgis map.
> But nothing happens. Qgis doesn't seem to produce any map file.
> Qgis displays no error message as well.
> what might the wrong be ?
> regards
