[Qgis-user] QGIS 0.9.1 does not start
Rainer M Krug rainer.qgis at krugs.de
Thu Jan 3 08:08:11 EST 2008
Hi Otto
thanks for the hint - I infact had to uninstall manually gcc 3.6.4 to
avoid the problem. It is working again - thanks.
Rainer
Otto Dassau wrote:
> Hi,
> On Wed, 02 Jan 2008 19:52:55 +0200
> Rainer M Krug <rainer.qgis at krugs.de> wrote:
>> Hi
>> I updated today to the new version of qgis (0.9.1-2.2) from the OpenSuse
>> repository
>> (http://download.opensuse.org/repositories/Application:/Geo/openSUSE_10.2/)
>>   and now qgis gives me the following error message when starting:
>> qgis: /usr/local/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found
>> (required by qgis)
>> (required by /usr/lib/libqgis_core.so)
>> The details about my installed qgis rpms are:
>> rkrug at ecolmod1:~> rpm -qa | grep qgis
>> qgis-plugin-grass-0.9.1-2.2
>> qgis-devel-0.9.1-2.2
>> qgis-0.9.1-2.2
>> I am running SuSE 10.2. I don't know if this is related,
> yes, I guess it is the problem ... I just started QGIS on 10.2 without a
> problem.
>> but I installed
>> a gdal 1.5 version I compiled myself to be able to read MrSid files. To
>> do that, I also compilesds and installed gcc and c++ 3.6.4.
> you need libstdc++.so.6 from the gcc version 4.1.3 (probably > 4), which
> normally is installed on opensuse 10.2 and was used to compile QGIS as well.
> Regards,
>  Otto
>> All dependances are OK (if I believe smart - which I do).
>> Any ideas welcome,
>> Rainer
