[Qgis-user] Linking tables in QGIS vector objects?
Agustin Lobo aloboaleu at gmail.com
Fri Jul 4 05:50:26 PDT 2008
Hi!
I have a vector map of land use, I'd like
to know if the following operations can be made
with QGIS:
1. Create a table with a list of the 7 Land use
types that are present so that I can select one land
use and get highlighted all polygons with
that land use.
2. Link this table of 7 land use categories to another table
of, for example, biomass/ha, so that
I can display a map of biomass/ha.
3. Calculate the product of the biomass/ha * ha
of each polygon and get it as a new variable in the
original table for display.
I konw I can do 2 and 3 in R and then bring the output
to QGIS, but would like to know if there is a QGIS way for this,
in particular the link between tables (through Postgis? I've
no idea on how to use it)
Thanks,
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
