[Qgis-user] qgis and postgis warning!
Salvator*eL*arosa s_larosa at libero.it
Mon Jul 14 01:43:04 PDT 2008
Jürgen E. Fischer-3 wrote:
> Hi Salvatore,
> On Sat, 12. Jul 2008 at 05:35:50 -0700, Salvator*eL*arosa wrote:
>> PostGIS is compiled with - with-geos = yes and
>> select postgis_full_version () gives me:
>> "POSTGIS="1.2.0" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
>> USE_STATS"
> Please quote the output of select postgis_version() for the database
> you're trying to use with qgis.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
Thank you for your reply....
select postgis_version() gives me:
"1.2 USE_GEOS=0 USE_PROJ=1 USE_STATS=1"
It seems that geos is not used by postgis!
How i can fix it??
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/Re%3A-qgis-and-postgis-warning%21-tp18422709p18439683.html
Sent from the qgis-user mailing list archive at Nabble.com.
