[Qgis-user] Ubuntu Version 0.11 has some defects
Alex Mandel tech_dev at wildintellect.com
Thu Jul 17 13:09:53 PDT 2008
It's 4.3 in the Hardy repos still. Also note that this was an upgrade
from a previously working 0.10 install to a 0.11 using the package
manager. Qt was not changed in this process. I can verify that this also
happened to me on the 64bit platform.
So the question is what changed between 0.10 and 0.11 that might trigger
this.
Timmie is your 8.04 install fresh or an upgrade? Mine is on an upgraded
machine, I'll try on a fresh install later today to see if that line
provides any new information.
Alex
Brian Bishop wrote:
> Timmie
> What version of python-qt4 are you running?
> Qgis from ppa.launchpad is compiled against python-qt4 from the ubuntu
> repositories (4.3.x). If you have a  later version of python-qt4, i.e.
> 4.4.x. then you will get issues similar to those you describe.
> Cheers
> Brian
> On Thu, 2008-07-17 at 00:31 +0200, Tim Michelsen wrote:
>> Hello,
>> yesterday my QGIS installation from
>> http://ppa.launchpad.net/qgis/ubuntu/
>> got updated.
>> I observed some issues:
>> * The documentation () was not installed
>> * The plug-in manager only allows to use native QGIS plugins:
>>     - only plugins from /usr/lib/qgis can be selected in the plugin-manager
>>     - I cannot add new repositories, the menu item is not there.
>>     - I cannot use plugins from ~/.qgis/python/plugins installed as
>> described in http://www.geog.uvic.ca/spar/carson/installplugins.html
>> below. The are just not present in the plugin-manager for activation.
>> Kind regards,
>> Timmie
