[Qgis-user] QGIS segfaulting
pcreso at pcreso.com pcreso at pcreso.com
Mon Jul 21 19:39:03 PDT 2008
Thanks guys...
I have not (yet) tried to install the 32bit version. The debug info as suggested by Maciej is below, (not the full bt info, but at least a more informative msg regarding the cause of the segfault).
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7f33cda8b720 (LWP 15049)]
0x00007f33cab306d0 in sincos () from /usr/lib64/libgdal.so.1
Hope this helps...
Brent
> > If you could install the
> qgis-debuginfo-0.11.0-2.4.x86_64.rpm from the
> > same repo and then follow the instructions here [1],
> it could help the
> > devs to identify the problem.
> > Maciek
