[Qgis-user] New User Help
maning sambale
emmanuel.sambale at gmail.com
Tue Jul 22 03:37:54 PDT 2008
On 7/22/08, Rob <the_shed at ozemail.com.au> wrote:
> Can someone point me in the right direction to start using this program..??
> I am trying to geo reference maps and cant get beyond that stage....
> are there some very basic help files, tutorials, etc available..???
> Cheers
> Rob
> Qgis-user mailing list
Before you begin, make sure you get the right projections for your map:
Menu Settings > Project Properties > Projection Tab
Use the georeferencer plugin to georef your map
Menu Plugins > Georeferencer
Select your GCPs, at least 4 GCPS are needed to georef your map. More
is better.
Choose your transformation type (linear/helmert)
Good luck!
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
