[Qgis-user] No projection systems available on 0.11 (ubuntu)
Agustin Lobo
aloboaleu at gmail.com
Thu Jul 24 03:55:06 PDT 2008
Relating this problem in my computer (ubuntu hardy):
1. These are the messages issued in the terminal with qgis 0.11
not providing the list of projection systems: perhaps this is
enlightening to somebody:
alobo at alobo-laptop:~$ qgis
Debug:
Debug: QgsApplication state:
Debug: Prefix :/usr
Debug: Plugin Path :/usr/lib/qgis
Debug: PkgData Path :/usr/share/qgis
Debug: Theme Path :/usr/share/qgis/themes/default/
Debug: User DB Path :/usr/share/qgis/resources/qgis.db
Debug: **********************************
Warning: No valid projection. Unable to set map units.
Debug:
Debug: Prefix :
Debug: Theme Path :
Debug: User DB Path :/resources/qgis.db
Critical: Data source is invalid
Critical:
Load failed due: Couldn't open geo.dbf
/usr/lib/python2.5/site-packages/osgeo/gdal.py:81: DeprecationWarning:
gdal.py was placed in a namespace, it is now available as osgeo.gdal
DeprecationWarning)
Raster Algebra: renderTest called!
2. I follow Maciej/Albin directions:
2.1. I "completely remove" all qgis related packages with Synaptic:
libqgis1-dev (0.11.0.2~hardy)
libqgis-core0.11 (0.11.0.2~hardy)
libqgisgrass0.11 (0.11.0.1~hardy)
libqgis-gui0.11 (0.11.0.2~hardy)
libqgispython0.11 (0.11.0~hardy)
python-qgis (0.11.0.2~hardy)
qgis-plugin-grass (0.11.0.2~hardy)
2.2. I review the files listed by Albin:
> /etc/ld.so.conf.d/qgis.conf
not in my system
> /home/albin/.qgis
> /home/albin/.config/QuantumGIS/qgis.conf
> /home/albin/.qgis/qgis.db
I rename .qgis to .gis_old
> /usr/lib/qgis/libqgis_core.so
not in my system
> /usr/lib/qgis/libqgis_gui.so
not in my system
> /usr/lib/qgis
it contains libevis.so (I put it there myself, wrong, it's for 0.10
only) I remove the directory
2.3. I install the same packages listed in 2.1,
and it works. Seems to have a problem with plugin Profile, I remove it.
This is now the output to the terminal:
Debug:
Debug: Prefix :/usr
Debug:
Debug: Prefix :/usr
Loaded /usr/lib/qgis/libcopyrightlabelplugin.so
Loaded /usr/lib/qgis/libdelimitedtextplugin.so
Loaded /usr/lib/qgis/libdelimitedtextprovider.so
Loaded /usr/lib/qgis/libgeorefplugin.so
Loaded /usr/lib/qgis/libgpsimporterplugin.so
Loaded /usr/lib/qgis/libgpxprovider.so
Loaded /usr/lib/qgis/libgrassplugin.so
Loaded /usr/lib/qgis/libgrassprovider.so
Loaded /usr/lib/qgis/libgridmakerplugin.so
Loaded /usr/lib/qgis/libmemoryprovider.so
Loaded /usr/lib/qgis/libnortharrowplugin.so
Loaded /usr/lib/qgis/libogrprovider.so
Loaded /usr/lib/qgis/libpggeoprocessingplugin.so
Loaded /usr/lib/qgis/libpostgresprovider.so
Loaded /usr/lib/qgis/libquickprintplugin.so
Loaded /usr/lib/qgis/libscalebarplugin.so
Loaded /usr/lib/qgis/libspitplugin.so
Loaded /usr/lib/qgis/libwfsplugin.so
Loaded /usr/lib/qgis/libwfsprovider.so
Loaded /usr/lib/qgis/libwmsprovider.so
BeautifulSoup was not found. Geocoders assuming malformed markup will
not work.
simplejson was not found. Geocoders relying on JSON parsing will not work.
Thanks!
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
