[Qgis-user] Cannot open DEM
Marco Pasetti
marco.pasetti at alice.it
Wed Jul 2 19:52:33 EDT 2008
Hi Mikhail,
you need to use the GRASS plugin in QGIS;
if I understood right you want to use the following raster data (I read from
the pointed web site):
Data Statistics (30M DEM)
Resolution: 30 meter
Available format: USGS DEM
Available geographic area: 7.5 minute quad, 1 degree block
Projection: UTM coordinate system, NAD 83, meters
so you need to:
1) create a new GRASS location with the correct EPSG ID code; I think it
should be: 3081
see http://www.epsg-registry.org/ for more details (put "nad83" in the
"name" search box of the "query by filter" page)
2) import the raster using r.in.gdal (from the r.in.gdal guide I have that
the "USGS ASCII DEM (.dem)" format is supported)
remember to select the command option: "override projection (use location's
projection)
Hope this helps,
Marco
----- Original Message -----
From: "Mikhail Umorin" <Mikhail.Umorin at twdb.state.tx.us>
To: <qgis-user at lists.osgeo.org>
Sent: Wednesday, July 02, 2008 11:09 PM
Subject: [Qgis-user] Cannot open DEM
> Hello —
> I am trying to load a DEM from here:
> http://www.tnris.org/datadownload/quad.jsp?Quad=Sabine%20Pass
> ("30m DEM" link :
> ftp://ftp2.tnris.org/Elevation/DEMs/30m/2993/g299317.zip)
> It is supposedly from USGS but I get error saying that it is not a
> supported raster source.
> What is the problem? Can someone help me?
> Mikhail.
> Qgis-user mailing list
