[Qgis-user] lines with arrowheads
Stefanie Tellex
stefie10 at media.mit.edu
Tue Jun 3 06:02:56 PDT 2008
My patch is a hack that hard codes the color and size of the markers. I
probably wouldn't have sent it at all if M S hadn't asked specifically
about arrow heads.
It would be cool to hook up the gui for formatting point geometries to
configure the start and end points of linestrings...
Stefanie
Andreas Neumann wrote:
> Hi Stefanie,
> I wonder if your patch just allows the green and red dots at starts and
> ends or if it would allow the placement of arbitrary shapes as markers?
> SVG, in my opinion, handles markers nicely, described at
> http://www.w3.org/TR/SVG11/painting.html#Markers
> Such an approach would allow a user to specify individual SVG markers to
> be placed at start-points, end-points and any vertices in between.
> Visualizing markers in between (marker-mid) is useful in many cases:
> visualization of the vertex positions of reference layers during editing
> a layer. Putting symbols at vertices can be useful in cartography:
> imagine the visualization of powerlines or cablecars where markers could
> be used to symbolize poles.
> The SVG model of markers either automatically calculates the orientation
> of the markers (using bisector angles of tangent vectors) or keeps the
> orientation as specified in the marker definition.
> I think for a mid-to longterm solution the approach SVG 1.1 full took
> would be useful for QGIS as well, but in the short run Stefanies patch
> would be good enough.
> Just my thoughts,
> Andreas
> Stefanie Tellex wrote:
>> I submitted a patch to do this a while back, but I don't think it was
>> accepted. I thought it was because it was decided to wait until a
>> more modular rendering pipeline was added, but I can't find the
>> messages about that in the thread. In fact the thread implies it
>> would be accepted, but if it made it into svn, I never noticed it.
>> (http://lists.osgeo.org/pipermail/qgis-developer/2008-February/003248.html)
>> The patches are attached. (arrows_in_linestrings draws arrows;
>> draw_start_and_stop draws a green dot at the start and a red dot at
>> the end.)
>> This message suggests an alternative solution that doesn't require
>> compiling qgis yourself:
>> http://lists.osgeo.org/pipermail/qgis-developer/2008-February/003250.html
>> Stefanie
>> M S wrote:
>>> One of the outputs from r.flow in GRASS is downslope flow lines.
>>> Without arrowheads (or some similar symbol like that) at the end of
>>> lines pointing which way is downhill, the lines become ambiguous.
>>> Is there a way to draw these lines with arrowheads? Or some other
>>> approach that might achieve this?
>>> Mark
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
