[Qgis-user] How to project data?
John Callahan john.callahan at UDel.Edu
Mon Jun 16 10:05:59 PDT 2008
Carson,
This is great.  This is exactly what I was looking for.  I'm also
looking at your other plugins and will probably try out several of these
as well.  Thanks!
For rasters, using GDAL works great; even projecting in batch mode can
be done with simple scripting.  However, including raster srs management
within QGIS will be very helpful for the majority of users.
- John
John Callahan
Geospatial Application Developer
Delaware Geological Survey
University of Delaware
227 Academy St, Newark DE 19716-7501
Tel: (302) 831-3584
Email: john.callahan at udel.edu
http://www.dgs.udel.edu
cfarmer wrote:
> John,
> Rasters cannot be projected in QGIS as of yet, however, you can use the
> georeferencing plugin to georeference them. As for vector layers, you can
> project them on the fly by assigning their projection using the projection
> dialog, or you can hard project them using my srsmanagement plugin. This
> plugin also allows you to define the projection.
> It is available here:
> http://www.geog.uvic.ca/spar/carson/
> or if you have QGIS > 0.9.2 you can add:
> http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
> to your python plugins repository in your plugin installer and install it
> directly from there.
> There are instruction at the address above as well...
> Cheers,
> Carson
>> I apologize for asking a question that seems so trivial but I am having
>> a hard time understanding how QGIS manages coordinate systems.  How do I
>> project a vector or raster dataset?  Just as important, how do I define
>> a projection/coordinate system?   Is this done through the QGIS
>> interface or do I accomplish this outside QGIS using command line
>> GDAL/OGC utilities?      Thanks for your help.
>> - John
>> John Callahan
>> Tel: (302) 831-3584
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Carson Farmer
> Spatial Pattern Analysis & Research Lab (SPAR)
> Department of Geography, University of Victoria
> cfarmer at uvic.ca
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080616/57b5b470/attachment.html>
