[Qgis-user] Re: add a gml layer
Tara Athan tara_athan at alt2is.com
Fri Jun 20 23:39:24 PDT 2008
Otto Dassau wrote:
> Hi Tara,
> maybe we should find out, if the windows QGIS version you use includes a GDAL
> with GML support. What version do you use?
The version that has problems with the GML import is QGIS v.10.0,
Windows package. The last-modified date on my copy of the installer is
May 11, if that makes any difference.
I don't know how to find out details of the GDAL that is included with
this build.
> I remember GML was not always
> included as a supported format in former QGIS Windows versions.
> regards,
>  Otto
> On Fri, 20 Jun 2008 14:16:00 -0700
> Tara Athan <tara_athan at alt2is.com> wrote:
>> I was able to get a lakes.gml file using the procedure Jürgen suggested,
>> using FW Tools.
>> It still does not load into QGIS v.10 (Windows XP) however.  The error
>> is the same as before-
>> ...\lakes.gml is not a valid or recognized data source
>> However I checked with a Windows build of QGIS v.11 that I received on
>> 6/6/08, and the layer DOES load!
>> I am guessing it is a re-emergence of closed Ticket #751 in the Io
>> Windows build.
>> Can anyone verify this?
>> Tara
