[Qgis-user] vector editing in QGIS - questions and issues (PostGIS	biased)
    Micha Silver
    micha at arava.co.il
    Tue Mar  4 03:08:26 PST 2008
Maciej Sieczka wrote:
> Marco Hugentobler pisze:
> > Maciek wrote:
> >> Marco wrote:
> Before you read on: NOTICE - I'm assuming that snapping = 0 is no
> different than snapping "disabled". Is this correct? If it is, maybe
> it would be better to remove the snapping checkbox for layers and use
> spinbox with numbers only to simplify the dialog?
>> Ok, I see what you mean. In the snapping dialog of the project should
>> be inserted the default snapping settings (which is snapping to the
>> active layer with the default snapping tolerance) in case the
>> snapping dialog was not changed already.
> Yes.
>> Otherwise, if a user changes any project property and clicks ok, the
>> snapping will be off for all layers.
> I think differently. As long as default QGIS-wide snapping is !=0, all
> layers which don't have inddividual setting set by the user, should
> have snapping set on equal to default setting - unless the user
> manually disables snapping for the given layer.
>> I don't think that unchecked layers should automatically have the
>> default snapping tolerance.
> Then what is the point of default snapping setting at all? Look - as
> long as you don't enter project properties and click OK, the default
> QGIS snapping is on for all layers in the project. Once you go to
> project props. and click OK, all snapping is suddenly disabled,
> although you did not modify any setting related to snapping. Imagine a
> user trying to guess what happened.
In the kind of jobs I do, and what I can imagine others do, I would NOT
want snapping automatically to all layers, but only the one layer I have
set to snap. Maybe, as you suggest, there should not be any default
project snapping setting at all, now that we have snapping for
individual layers.
> Note also that this was different in QGIS before introducing
> individual snapping setting per layer. You only had the QGIS-wide
> snapping setting, which was always active, for all layers. Now as soon
> as you go to project settings for whatever reason and press OK that
> snapping is disabled. This should be avoided.
>> Because it is possible that a user don't want to snap to some layers
>> at all.
> The user can disable snapping for a certain layer, if he needs to.
> Another thing - IMO users more often need snapping than they don't.
> Help users not to digitize overlapping features by default, eg.
> promote using snapping rather than not using it. I'd be also in favor
> of enabling the QGIS "topological editing" feature by default.
> What I hate most in GIS are all those overlapping polygons and lines
> which I have to tediously correct topology for, re-calculate their
> area and length, explain the vendor what is wrong about his data.
> Please promote topological practices.
> Maciek
> Qgis-user mailing list
> This mail was sent via Kinneret Mail-SeCure System.
Micha Silver
Arava Development Co
+972-8-6592270
