[Qgis-developer] Re: [Qgis-user] vector editing in QGIS - questions and issues (PostGIS biased)
Maciej Sieczka
tutey at o2.pl
Fri Mar 7 10:41:45 PST 2008
Marco Hugentobler pisze:
> So the main problem seems to be confusion that users might have about default
> settings and project settings.
> In my opinion it is enough to add a note in the project snapping dialog that
> after pressing 'ok', the default setting is overwritten.
> Similarly, in the options dialog, it could be mentioned that this may be
> overwritten by more specialised project settings.
This confusion is one bad thing. An appropriate information would help.
However, there are other bad things:
1. You can't restore global snapping once you press OK in Snapping
Options. You will have to set individual snapping for each new layer in
the project from then on.
2. Only in per-layer snapping settings it is possible to choose the
snapping mode (to vertex, to segment, to both). If you want to use this
great new feature which is snapping to both, you will have to set it in
Snapping Options, for each single layer. Naturaly after you do it even
for a single layer, you don't have any global snapping active anymore,
so you are forced to set snapping for each new layer in your project
until forever :).
In my other email from 05.03.2008 17:24 i describe how, as I believe it,
to prevent these issues and let the global and individual snapping
co-exist cheerfully.
If what I suggest is not feasible, at a minimum please add the
possibility to define the snapping mode in Settings > Options >
Digitizing. So that one does not have to settle for tedious
configuration of snapping mode for each single layer if he wants to
benefit from snapping to segment or to vertex and segment.
Maciek
