[Qgis-user] Panning while editing vector layers
Maciej Sieczka tutey at o2.pl
Wed Mar 19 13:51:53 PDT 2008
Carlos Dávila pisze:
> Is there any way to pan a map while editing a vector layer without using
> the overview tool? If the map is quite zoomed in it's almost impossible
> to move to the right place with the overview and if you click pan icon
> on the toolbar your edits disappear.
Moving mouse cursor with space pressed does it. Not only in digitizing mode.
It would be great if the panning key was configurable though, as space
is also used eg. for toggling layers visibility. If you press space to
pan on map canvas when your layers list is active, you check/uncheck the
hihglited layer instead. Then in order to activate space for panning you
need to select eg. the identify tool and click on the canvas first. Such
switching is a bit tedious and might be not intuitive for new users.
This could be avoided if one was able define a different key for panning.
Maciek
