[Qgis-user] Projections Management Tool
Carson Farmer
cfarmer at uvic.ca
Mon Mar 24 12:47:54 PDT 2008
I don't think this made it through properly last time, so I'll resubmit
it, sorry about the double posting if it did...
Thanks Paolo for the suggestion...
I have now created a repository for testing out my 'in development' plugins:
For those of you new to this sort of thing (like myself), to use it
follow these simple steps:
1) Open up QGIS (preferably 0.9.2-rc1 for these plugins to work smoothly)
2) Go to your 'QGIS Plugin Installer' and click on the 'Add' button to
add a new repository.
3) Give the new repository a name (I used cfarmer testing repo)
4) Under URL enter: http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
5) Hit 'OK' and then click on 'Get List'
6) You should now have a list of available plugins (right now I have a
centroids plugin and the projections management plugin in there)
7) Just click on the plugin you want to install, and voila! Now go and
activate the plugin under 'Plugins' > 'Plugin Manager...'
I've tested this a couple of times and it seems to work, just make sure:
a) you don't already have a folder name 'centroids' or 'srsmanagement'
in your plugins directory (why would you, those are MY plugin names!)
b) you have permissions to upzip into those folders
> Paolo Cavallini wrote:
>> Carson Farmer ha scritto:
>>> Hello List,
>>> I have developed two projection management tools ( using python ) which
>>> I would like to disseminate to the general public, but rather than
>> Hi Carson.
>> Thanks for your work. Why not setting up a custom repository? It is
>> simple, and makes installing the plugin very smooth (if it works - some
>> plugins still have problems with this).
>> How is this done? Just write an xml file like this:
>> <plugins>
>> <pyqgis_plugin name="xxx" version="yyy">
>> <description>Write your description here</description>
>> <homepage/>
>> <file_name>srsmanagement.zip</file_name>
>> <author_name>Licenced under GNU GPL (General Public License) v2 by
>> ....</author_name>
>> <download_url>http://www.geog.uvic.ca/spar/carson/srsmanagement.zip</download_url>
>> </pyqgis_plugin>
>> </plugins>
>> (thanks Martin Dobias for teaching me this!).
>> I can test it if you set it up.
>> All the best.
>> pc
