AW: [Qgis-user] writing a new renderer in python
Anita Graser
anitagraser at gmx.at
Tue Mar 25 01:35:23 PDT 2008
Hi Marco,
Thank you, you saved my day.
... Those Renderers are really confusing.
-------- Original-Nachricht --------
> Datum: Sat, 22 Mar 2008 06:58:46 +0100
> Von: "Hugentobler Marco" <marco.hugentobler at karto.baug.ethz.ch>
> An: "Anita Graser" <anitagraser at gmx.at>, qgis-user at lists.osgeo.org
> Betreff: AW: [Qgis-user] writing a new renderer in python
> Hi Anita,
> To make QGIS fetch the attributes, you need to implement
> QgsRenderer::classificationAttributes()
> in your renderer subclass. It returns a QgsAttributeList (that is a
> typedef for QList<int>) and tells QGIS, what attributes the renderer class needs.
> Only the specified attributes are fetched from the datasource (for
> performance reasons).
> Also, there is the method QgsRenderer::needsAttributes() that should
> return true (is only used in the legend of QGIS, the method seems highly
> redundant with classificationAttributes() and is a candidate for removal).
> Hope it helps,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Anita Graser
> Gesendet: Fr 21.03.2008 13:12
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] writing a new renderer in python
> For my project I want to visualise speed on streets with a continuous
> color renderer. I'd like it to show slow in red then change to yellow then to
> green. Unfortunately QgsContinuousColorRenderer only allows to use two
> colors. So I'm trying to write a new renderer inheriting QgsContinuousColor
> Renderer.
> Is it possible to write a new renderer in python?
> I found some problems which I don't understand:
> 1.
> I tried to rewirte the renderFeature function:
> def renderFeature(self, painter, feature, image, scalefactor, selected,
> widthScale=1):
> attrs = feature.attributeMap()
> fvalue = float(attrs[self.classificationField])
> However, attributeMap() seems to always return a dictionary of length 1
> allthough there should be 12 attributes. So I can't get a value for fvalue.
> 2.
> If I catch the exception caused by problem 1 and set a default value the
> function will continue to it's end. But then, I get a typeError:
> TypeError: invalid result type from My3ColorRenderer.renderFeature()
> I'm confused because I thought that this function returns void ...
> Anyone got an idea what I'm doing wrong?
> Thank you!
> My Code:
> from PyQt4.QtCore import *
> from PyQt4.QtGui import *
> from qgis.core import *
> from qgis.gui import *
> class My3ColorRenderer(QgsContinuousColorRenderer):
> def __init__(self,vectorType):
> self.vectorType=vectorType
> QgsContinuousColorRenderer.__init__(self,vectorType)
> def setMiddleSymbol(self,symbol):
> self.mMiddleSymbol=symbol
> def middleSymbol(self):
> return self.mMiddleSymbol
> def name(self):
> return "FleetVis3ColorRenderer"
> def symbols(self):
> list=[]
> list.append(self.mMinimumSymbol)
> list.append(self.mMiddleSymbol)
> list.append(self.mMaximumSymbol)
> return list
> def setClassificationField(self,id):
> self.classificationField=id
> selected, widthScale=1):
> #first find out the value for the classification attribute
> # ??? i dont know why it doesnt work ...
> try:
> except:
> fvalue=50.0
> minvalue = float(self.minimumSymbol().lowerValue())
> maxvalue = float(self.maximumSymbol().lowerValue())
> middlevalue = minvalue + maxvalue
> middlevalue=middlevalue/2
> mincolor=QColor()
> maxcolor=QColor()
> if self.vectorType == QGis.Line or self.vectorType == QGis.Point:
> mincolor = self.minimumSymbol().pen().color()
> middlecolor=self.middleSymbol().pen().color()
> maxcolor = self.maximumSymbol().pen().color()
> else:#if polygon
> painter.setPen(self.minimumSymbol().pen())
> mincolor = self.minimumSymbol().fillColor()
> middlecolor=self.middleSymbol().fillColor()
> maxcolor = self.maximumSymbol().fillColor()
> if (maxvalue - minvalue)!=0:
> if(fvalue<middlevalue):
> red = int (middlecolor.red() * (fvalue - minvalue) /
> (middlevalue - minvalue) + mincolor.red() * (middlevalue - fvalue) /
> (middlevalue - minvalue))
> green = int (middlecolor.green() * (fvalue - minvalue) /
> (middlevalue - minvalue) + mincolor.green() * (middlevalue - fvalue) /
> blue = int (middlecolor.blue() * (fvalue - minvalue) /
> (middlevalue - minvalue) + mincolor.blue() * (middlevalue - fvalue) /
> elif(fvalue==middlevalue):
> red=int(middlecolor.red())
> green=int(middlecolor.green())
> blue=int(middlecolor.blue())
> else:
> red = int (maxcolor.red() * (fvalue - middlevalue) /
> (maxvalue - middlevalue) + middlecolor.red() * (maxvalue - fvalue) / (maxvalue -
> middlevalue))
> green = int (maxcolor.green() * (fvalue - middlevalue) /
> (maxvalue - middlevalue) + middlecolor.green() * (maxvalue - fvalue) /
> (maxvalue - middlevalue))
> blue = int (maxcolor.blue() * (fvalue - middlevalue) /
> (maxvalue - middlevalue) + middlecolor.blue() * (maxvalue - fvalue) /
> else:
> red = int (mincolor.red())
> green = int (mincolor.green())
> blue = int (mincolor.blue())
> if self.vectorType == QGis.Point:
> pen = self.minimumSymbol().pen()
> pen.setColor ( QColor(red, green, blue) )
> pen.setWidthF ( widthScale * pen.width() )
> brush = self.minimumSymbol().brush()
> brush.setColor ( QColor(red, green, blue) )
> brush.setStyle ( Qt.SolidPattern )
> img = QgsMarkerCatalogue.instance().imageMarker (
> self.minimumSymbol().pointSymbolName(), self.minimumSymbol().pointSize(),pen, brush)
> if scalefactor:
> scalefactor = 1
> elif self.vectorType == QGis.Line:
> painter.setPen( QPen(QColor(red, green,
> blue),int(widthScale*self.minimumSymbol().pen().width()) ))
> else:
> painter.setBrush(QColor(red, green, blue))
> painter.setPen(Qt.NoPen)
> Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
> Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
> Qgis-user mailing list
