[Qgis-user] KML in QGIS
Sebastien Vial sebastien.vial at gmail.com
Sat Mar 29 08:53:33 PDT 2008
Hi
On windows, it works ! I can open KML files
I would like to WRITE some kml files ; ogr can, qgis uses ogr but can't
write kml...
Do I need to write a plugin ?
Seb
2008/3/28, Jacolin Yves <yjacolin at free.fr>:
> Hi,
> Thanks ludo, I think the problem come from my ogr installation which
> doesn't
> support kml in reading. Some configuration parameter should be missing.
> Y.
> Le Friday 28 March 2008 11:43:52 ludo, vous avez écrit :
> > Hi all
> >  I'm using QGIS 0.9.2 RC1 on windows and I haven't any problem for
> display
> > kml layer. (add vector layer / type : all files) After you can export
> the
> > layer into shapefile.
> > Ludovic
> > > Message du 28/03/08 10:59
> > > De : "Sebastien Vial"
> > > A : "Jacolin Yves"
> > > Copie à : qgis-user at lists.osgeo.org
> > > Objet : Re: [Qgis-user] KML in QGIS
> > > Hi all   Very interesting feature !! (adding a kml vector layer
> doesn't
> > > work in 0.9.2.rc1 on windows)   I'm teaching GIS and I need to
> *export*
> > > KML form QGIS layer ; I planned to write a python plugin (with
> > > gdal/ogr) ; now I'm using a ogr2ogr shell script... Any informations
> will
> > > be welcome !   Thanks a lot   Seb
> > >   2008/3/28, Jacolin Yves <yjacolin at free.fr>: Hi,
> > > I was looking for KML support in QGIS when I find this bug report :
> > > https://trac.osgeo.org/qgis/ticket/767
> > > Does it mean there is a way to read kml in QGIS, if yes, how can I do
> it?
> > > If the answer is no, can I fill a bug as a new feature?
> > > Thanks,
> > > Y.
> > > Yves Jacolin
> > > http://softlibre.gloobe.org
> > >  _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Sébastien VIAL
> > > Prof d'Info - Resp. TIC/Comm - Formateur SIG
> > > Lycée Agricole du Balcon des Ardennes
> > > http://www.lebalcon.fr
> > >  tel : 03-24-57-66-71
> > > [ (pas de nom de fichier) (0.1 Ko) ]
> Yves Jacolin
Sébastien VIAL
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080329/70d264dd/attachment.html>
