[Qgis-user] calculate statistics on an attribute table
Maciej Sieczka
tutey at o2.pl
Sun May 4 08:46:18 EDT 2008
Mars Sjoden pisze:
> Is there a way to quickly calculate statistics on an attribute table
> column?
Not that I know of. A workaround for doing this with external software:
1. open attrubute table in QGIS
2. select all rows (select first one, go to bottom of the table, press
ctrl selecting the last row)
3. ctrl+c
4. open some spreadsheat/statistics software
5. paste
If your layer is PostGIS you can use PostgreSQL advanced stats features
directly. If you want to put your SHP into PgSQL use the QGIS SPIT
plugin or shp2pgsql CLI utility.
Best,
Maciek
P.S.
Please don't hi-jack threads.
