[Qgis-user] symbol lookup error on kubuntu 8.04
andrea pacifici
pacifici at gmail.com
Wed May 7 12:20:21 EDT 2008
Hi
2008/5/7 Tim Sutton <tim at linfiniti.com>:
> Hi (please reply on-list so others may learn from solutions found if
> they encounter similar problems)
> 2008/5/7 andrea pacifici <pacifici at gmail.com>:
> > ok, thanks
> > I need /media/data_2/isis3/isis/3rdParty/lib.
> > How can I adjusts ldconfigs to ensure the libraries in /usr/lib get
> priority
> It depends on how your system is configured really, and how the isis
> app you have installed itself. Firstly check your ~./bashrc to check
> if anything is setting LD_LIBRARY_PATH variable.
LD_LIBRARY_PATH there is not in my ~./bashrc file
> Secondly if you have
> root access to your machine you can inspect and adjust
> /etc/ld.so.conf.
here there is only:
include /etc/ld.so.conf.d/*.conf
> You might also want to check if anything got changed
> in /etc/bash_profile etc.
anything in this also
> You should probably take this up with
> developers of the ISIS app that you are using since it seems in
> setting it up the process has broken your lib search order.
> Regards
Thanks a lot
> Tim
> > Thanks
> > Andrea
> > > Hi
> > > > Yes, thanks. It is quite long
> > > No problem.
> > > > andrea at solaria:~$ ldd /usr/lib/libqgis_gui.so.0.10
> > > > linux-gate.so.1 => (0xb7fa1000)
> > > > libQtGui.so.4 =>
> > /media/data_2/isis3/isis/3rdParty/lib/libQtGui.so.4
> > > > (0xb7a38000)
> > > Ok that looks like the cause of your problem - it looks like you have
> > > some other copy of qt4 on your system that has priority in the library
> > > load sequence. Either remove the libs in
> > > /media/data_2/isis3/isis/3rdParty/lib (if not needed) or adjust your
> > > ldconfigs to ensure the libraries in /usr/lib get priority.
> > > 8<----------snip------------
> > > Regards
> > > Tim Sutton
> > > QGIS Project Steering Committee Member - Release Manager
> > > Visit http://qgis.org for a great open source GIS
> > > openModeller Desktop Developer
> > > Visit http://openModeller.sf.net for a great open source ecological
> > > niche modelling tool
> > > Home Page: http://tim.linfiniti.com
> > > Skype: timlinux
> > > Irc: timlinux on #qgis at freenode.net
> > _____________________________
> > Dott. Geol. Andrea Pacifici, Ph.D.
> > Via della Billona n°1093,
> > 55100 Lucca (Lu)
> > Cell. 328-0991808
> > E-Mail pacifici at gmail.com
> Tim Sutton
> Skype: timlinux
55100 Lucca (Lu)
Cell. 328-0991808
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20080507/64600836/attachment.html
