[Qgis-user] wishlist:ala ArcView Habitat Digitizer Extension
Richard Duivenvoorde
rdmailings at duif.net
Thu May 15 06:40:05 EDT 2008
Hi Maning,
I've started a 'Python plugin ideas/wishlist' in the wiki some time ago:
http://wiki.qgis.org/qgiswiki/PythonPluginIdeas
If you think this is doable in python, feel free to add your 'wish' to
the list :-)
Regards,
maning sambale wrote:
> Hi,
> I've used this before:
> "The Habitat Digitizer Extension was designed to use a hierarchical
> classification scheme to attribute polygons, lines, and points
> delineated by visually interpreting georeferenced images such as
> aerial photographs, satellite images, and side scan sonar. The
> extension allows users to create custom classification schemes and
> rapidly delineate and attribute polygons, lines, and points using
> simple menus and dialogs.
> Several advantages to using classification schemes with a hierarchical
> structure include: the detail of habitat categories can be expanded or
> collapsed to suit user needs, the thematic accuracy of each
> category/hierarchical level can be determined, and additional
> categories can be easily added or deleted at any level of the scheme
> to suit user needs."
> http://arcscripts.esri.com/details.asp?dbid=10556
> Are there others who used this before? Maybe we can "encourage"
> plugin developers to develop such a plugin. Need it very much, but
> can't code :(
> cheers,
> maning
> | __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
> | '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
> | /'.-c |Linux registered user #402901, http://counter.li.org/ |
> | | /T |http://esambale.wikispaces.com|
> | _)_/LI
> Qgis-user mailing list
