[Qgis-user] zoom to point/edit point coordinates
Tim Sutton tim at linfiniti.com
Wed Nov 12 08:38:51 PST 2008
Hi
On Wed, 2008-11-12 at 14:47 +0000, Carson Farmer wrote:
> > I prefer your idea because your way a user could just keep entering
> > coordinate pairs to build up a feature without any need for mouse
> > clicks. Since docs can be stacked / tabbed it neednt consume a lot of
> > screen real estate. The disadvantage of your idea is that we would
> > need to implement the concept of a selected vertex probably...
> You might not need to, for example, you setup the following:
>  If a vertex is selected, the 'apply' button would read 'adjust vertex',
> otherwise, it would read 'add vertex'.
> This way it becomes both a new vertex and change vertex tool!
Right but that was the implied behaviour already from the discussion
above - the issue more relates to the fact that you cant 'highlight' /
select a vertex (only a whole feature), which means its difficult to
know which vertex should be affected when you click 'adjust vertex'. Of
course aforementioned applies only to line / polygon layers, with point
layers the problem doesnt exist.
Regards
Tim
> Carson
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081112/26d0fad2/attachment.sig>
