[Qgis-user] No coordinate capture in preview2 for ubuntu
Tim Sutton tim at linfiniti.com
Wed Nov 12 22:50:40 PST 2008
Hi Agustin
On Wed, 2008-11-12 at 18:33 +0100, Agustin Lobo wrote:
> After installing the newest package for ubuntu
> (1.0preview17)
> the Coordinate Capture is there.
Yay
> Two plugins that are installed by default still do not work:
Ok these are both add on plugins not ones shipped with QGIS. The reason
they dont load is because they don't use the updated API yet. The
immediate fix for the issues listed is:
in /home/alobo/.qgis//python/plugins/valuetool/valuewidget.py change
line 98 to read:
layer = self.canvas.layer(i)
in /home/alobo/.qgis//python/plugins/pypostgis/Pypostgis.py change line
22 to read:
self.action = QAction(QIcon(":pypostgis.png"), "Python Postgis SQL",
self.iface.mainWindow())
However fixing those lines might just result in a line further down
giving an error  - its better to wait for the plugin writers to provide
new versions updated to the QGIS 1.0 API. The API is still not frozen
yet so I suggest the plugins writers wait until we announce the API
freeze.
Regards
Tim
> Value tool
> Traceback (most recent call last):
>    File "/home/alobo/.qgis//python/plugins/valuetool/valuewidget.py",
> line 98, in printValue
>      layer = self.canvas.getZpos(i)
> AttributeError: getZpos
> PyPostGis
>    File "", line 1, in
>    File "/home/alobo/.qgis//python/plugins/pypostgis/Pypostgis.py", line
> 22, in initGui
> SQL", self.iface.getMainWindow())
> AttributeError: getMainWindow
> Thanks a lot to the so many that make all this magic
> possible.
> Agus
> Tim Sutton wrote:
> > Hi
> > Thats strange. Can you look in your filesystem and see if its present in:
> > /usr/lib/qgis/libcoordinatecaptureplugin.so
> > Are you using the Ubuntu packages? If yes and its not there then I
> > suspect its missing in the debian packaging stuff. Juergen can you add
> > it in there if its missing?
> > Regards
> > Tim
> > 2008/11/12 Agustin Lobo <Agustin.Lobo at ija.csic.es>:
> >> But unfortunately it's not or cannot find it,
> >> see the attachment (probably deleted for the list)
> >> I have all "by default" plugins activated except
> >> Value tool and Pypostgis, which cause errors.
> >> Agus
> >> Tim Sutton wrote:
> >>> Hi
> >>> 2008/11/12 Agustin Lobo <aloboaleu at gmail.com>:
> >>>> Why there is no coordinate capture tool
> >>>> in the preview2 for ubuntu?
> >>> It should be there - you probably just need to enable it in the plugin
> >>> manager....
> >>> Regards
> >>> Tim
> >>>> Thanks
> >>>> Agus
> >>>> Dr. Agustin Lobo
> >>>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> >>>> LLuis Sole Sabaris s/n
> >>>> 08028 Barcelona
> >>>> Spain
> >>>> Tel. 34 934095410
> >>>> Fax. 34 934110012
> >>>> email: Agustin.Lobo at ija.csic.es
> >>>> http://www.ija.csic.es/gt/obster
> >>>> _______________________________________________
> >>>> Qgis-user mailing list
> >>>> Qgis-user at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Dr. Agustin Lobo
> >> 08028 Barcelona
> >> Spain
> >> Tel. 34 934095410
> >> Fax. 34 934110012
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081113/eb4d3e34/attachment.sig>
