[Qgis-user] Win qgis1.0preview2 crashes
Agustin Lobo Agustin.Lobo at ija.csic.es
Sat Nov 15 03:41:29 PST 2008
Tried, no luck. This is what I did:
1. Uninstall Qgis
2. Run regedit in the windows terminal
3. Searched for quantumgis in the registry editor
4. Deleted the quantumgis folder from the software folder in the registry
5. Rebooted
6. Installed QGIS
7. Run qgis and after displaying a vector file tried to set
Properties and... crashed.
I'm giving up, will not use the win version of qgis on this computer,
the ubuntu version works and I use ubuntu most of the time.
Thanks to all who tried to help!
Agus
Goyo escribió:
> I found this sometime ago and deleting it solved a problem with toolbars
> configuration[1]. Maybe it helps you.
> /hkcu/software/quantumgis
> [1] http://lists.osgeo.org/pipermail/qgis-user/2008-February/002339.html
> El vie, 14-11-2008 a las 11:49 +0100, Agustin Lobo escribió:
>> Thank you all for the answers:
>> 1. Re-installing windows: not being a windows user, I'd rather
>> get another PC than re-installing windows. It's true that qgis preview2
>> works fine on other win computers (even the old one I have at home), but
>> it's also true that other programs work fine on this laptop and that I
>> would have to reinstall too many things.
>> 2. Registry cleaning: looks feasible. I have a program
>> called registry cleaner, what should I look for?
>> 3. "video driver; I'd look for an updated version": mine is Mobile Intel
>> 945GM Express Chipset 6.14.10.4436 28/11/2005 and have not found
>> anything better/more modern.
>> May be the cause is that I have SP2 and not SP3? (I'm reluctant
>> to upgrade to SP3 as this caused lots of problems in
>> another computer)
>> Agus
>> Goyo wrote:
>>> In case it is a configuration issue, deleting directories in Windows
>>> won't work because it's stored in the registry. Maybe some registry
>>> cleaning can help.
>>> El jue, 13-11-2008 a las 16:17 +0100, Agustin Lobo escribió:
>>>> Dear list,
>>>> Regarding the windows version, I have the same problem with preview2
>>>> than I had with preview1 on a winXP laptop:
>>>> after few operations, QGIS always crashes. In
>>>> particular, after selecting the Properties tab of any
>>>> layer. I've uninstalled, deleted the directory, rebooted,
>>>> installed again... same problem.
>>>> This problem does not occur on other win machines
>>>> (although I've not been able to test on many, I'm not
>>>> a windows user most of the time). I've run the program
>>>> from a console, but no messages are printed to it in
>>>> the win version.
>>>> Any clue on what could be happening? It's annoying, as
>>>> this is the laptop that I use most of the time, and some
>>>> people want to see qgis running on win. The same
>>>> laptop runs ubuntu 8.04, no problem there.
>>>> Thanks!
>>>> Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
