[Qgis-user] getting QgsMapCanvasSnapper to work
Carson Farmer carson.farmer at gmail.com
Tue Nov 18 15:25:27 PST 2008
> I used your code lines and started the debugger. It seems that the QgsMapCanvasSnapper works correctly. I think the problem has to do with the QList reference in the binding:
> int snapToCurrentLayer( const QPoint& p, QList<QgsSnappingResult>& results, QgsSnapper::SnappingType snap_to, double snappingTol = -1, const QList<QgsPoint>& excludePoints = QList<QgsPoint>() );
I wonder if this is related to a similar problem I was having with
python bindings for uniqueValues on QgsVectorDataProvider?
> But then Python complains about a wrong type of the results parameter with your code. I tried to use a 'QList' instead of '[]', but it seems there is no QList in PyQt?
> Python experts: How can we deal with QList in PyQGIS?
Short answer: you should be able to use a python list in place of a QList
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Möri Cedric
> Gesendet: Di 18.11.2008 18:43
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] getting QgsMapCanvasSnapper to work
> Hi all!
> I'm trying to snap a vertex with my python plugin. (Many thanks to Martin for the quick work with the bindings!)
> My code looks like this:
> def canvasReleaseEvent(self,event):
>    x = event.pos().x()
>    y = event.pos().y()
>    startingPoint = QPoint(x,y)
>    result = []
>    excludePoints = []
>    snapper = QgsMapCanvasSnapper(self.canvas)
>    snapper.snapToCurrentLayer (startingPoint,result,QgsSnapper.SnapToVertex, 10000, excludePoints)
>    print "result: ",result
> The problem is, whatever I do, the result keeps empty. I tried to play with tolerance and scale and I'm quite sure it has to find a vertex but without any success (the layer unit is meter).
> So I thought about using QgsSnapper directly. But I'm not able to set it up properly. Doing the following snippet always leads to a attribut error on the snapLayer struct.
>  snapLayer = QgsSnapper.SnapLayer
>  snapLayer.mLayer = self.iface.mapCanvas().currentLayer()
>  snapLayer.mTolerance = 1000
>  snapLayer.mSnapTo = QgsSnapper.SnapToVertex
> So, if anyone has a hint why the QgsMapCanvasSnapper doesn't want to give me a result or how I set up the struct correctly, it would be wonderful to share it with me :-)
> Best regards and kudos to all the helping people here on the list!
> Cédric
> mit freundlichen Grüssen
> Cédric Möri
> GIS-Informatiker
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon: +41 (0)32 627 24 75
> Telefax: +41 (0)32 627 22 14
> mailto:cedric.moeri at bd.so.ch
> http://www.agi.so.ch
> Qgis-user mailing list
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
