[Qgis-user] Problems with grass plugin
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Nov 19 06:42:53 PST 2008
On Wed, 2008-11-19 at 14:31 +0100, Agustin Lobo wrote:
> If I use the arrows to edit the command (which is most used in grass), I
> always get weird behavior, cannot edit as I do in an xterm. Sometimes
> the right arrow does not work after I've used the left arrow, the lines
> that I recover with the up arrow are broken, the terminal gets stuck
> very often...
> Agus
> Barbosa, A. Marcia wrote:
> > "Anyway, is there any kind of specific doc on the grass
> > plugin? I'm particularly confused by r.mapcalc (I used grass
> > in the very old days and use r.mapcalc in the terminal). Any
> > doc or tutorial on how to use the graphic interfase? Do you use it?
> > BTW, I always have problems with the grass terminal opened from
> > the plugin and have to open an xterm. This is not big deal for me,
> > but students find it very confusing. Could the grass terminal be fixed?"
A ticket about the GRASS shellfrom within QGIS is here:
https://trac.osgeo.org/qgis/ticket/1414
Regards, Nikos
