[Qgis-user] Running "QGIS 1.0" in "Gentoo"
José María Michia jose.maria.michia at gmail.com
Wed Nov 19 06:56:52 PST 2008
I have built "QGIS 1.0" from source file "QGIS-1.0.0-0.1.pre2.src.rpm"
wget
http://www.silfreed.net/download/repo/packages/qgis/qgis-1.0.0-0.1.pre2.src.rpm
rpm2tar qgis-1.0.0-0.1.pre2.src.rpm
tar xvf qgis-1.0.0-0.1.pre2.src.tar
tar xvf qgis_1.0.0-pre1.tar.gz
cd qgis_1.0.0-pre1
mkdir build
cd build
ccmake ..
cmake .
make
sudo make install
When I start QGIS, it gives an error and does not load the plugin "Python".
The error is:
Couldn't load PyQGIS.
Python support will be disabled.
Traceback (most recent call last): File "", line 1, in
ImportError: No module named qgis.core
Thanks for any advice to get 'Python' work.
Werner: please send me the ebuild, I like to try it. Thanks
José María
2008/11/19 Werner Macho <werner.macho at gmail.com>
> Hi!
> I wrote a small script and an qgis 1.0.0 ebuild to check out qgis from SVN
> and afterwards compile and install it (as it is supposed to be done by
> ebuild)
> If you want i can send both to you with a small explanation. It just only
> compiles out of svn trunk - so you have to live with the latest bugs too :)
> And - I had no time to include postgis support - so youo probably have to
> live without postgis.
> regards
> Werner
>> There any way to use the "QGIS 1.0" in "Gentoo"? Thanks for any advice.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081119/67765a18/attachment.html>
