[Qgis-user] Problem with grass plugin: r.statistics
Agustin Lobo aloboaleu at gmail.com
Fri Nov 21 02:18:31 PST 2008
I select 2 layers in the raster plugin menu for r.statistics but
according to what is written to the output tab, the
layers that are actually used are different:
r.statistics base=delme at all cover=ASP_SLP at all method=median output=delme2
while I actually have selected  NDVI2003 at all as base in the menu
(see http://aloboaleu.googlepages.com/r.statistics1.jpg
and http://aloboaleu.googlepages.com/r.statistics2.jpg )
Anyway, r.statistics does not work even from the command line. In:
r.statistics base=NDVI2003 at all cover=ASP_SLP at all method=median output=delme2
delme2 is identical to NDVI2003
(but this second one is for the grass list, actually).
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
