AW: [Qgis-user] splitting polygons
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Fri Nov 28 07:36:24 PST 2008
Hi Micha
Do you have the possibility to test with current svn version?
I recently fixed a feature splitting bug that occured in connection with geos2 library. I think this is the same one you described.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Micha Silver
Gesendet: Fr 28.11.2008 12:47
An: "Jürgen E. Fischer"; Qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] splitting polygons
Jürgen E. Fischer wrote:
> Hi Micha,
> On Wed, 26. Nov 2008 at 21:52:27 +0200, Micha Silver wrote:
>> Looks to me like this bug:
>> http://trac.osgeo.org/qgis/ticket/1025
>> has been resurrected from the grave.
> Can you supply a stack trace or even better a testcase to reproduce the
> problem?
Hello Jurgen
Here's what I did:
Went to a second Ubuntu machine (8.04), running qgis Metis 0.11, (just
to make sure the crash I got before with 1.0.0 wasn't just a fluke. ) I
created a simple polygon shapefile. Then I used the split polygon tool
to split one feature - no problems.
Next I did the upgrade on this machine to get 1.0.0 Preview II. I now
ran the new qgis with strace, opened that same shapefile, and tried to
split one of the polygons, and got the same crash as on the first
machine. Here's what appeared on the console:
micha at akev:~/geodata/test_poly$ strace -o qgis_trace.txt qgis &
[1] 21501
micha at akev:~/geodata/test_poly$ Python support ENABLED :-)
Loading python plugins
Warning: QObject::connect: Connecting from COMPAT signal
(QAction::activated())
Loaded : Plugin Installer (package: plugin_installer)
Plugin loading completed
Warning: QPainter::begin: Cannot paint on a null pixmap
Warning: QPainter::end: Painter not active, aborted
Warning: QgsCoordinateReferenceSystem::getRecord failed :  select * from
tbl_srs where parameters='+proj=tmerc +lat_0=31.73439361111111
+lon_0=35.20451694444445 +k=1.0000067 +x_0=219529.584 +y_0=626907.39
+ellps=GRS80 +units=m +no_defs'
Warning: QgsCoordinateReferenceSystem::findMatchingProj will only work
if prj acr ellipsoid acr and proj4string are set!...
[1]+  Done                    strace -o qgis_trace.txt qgis
and I put the resulting trace here:
http://my.arava.co.il/~micha/qgis_trace.tar.gz
Thanks for your help.
Regards,
Micha
> Jürgen
Qgis-user mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-user
