[Qgis-user] Testing qgis_rasterlayertest ***Failed
Chris h
chris123 at magma.ca
Thu Nov 20 17:09:45 EST 2008
On Thursday 20 November 2008 10:24:59 Peter Ersts wrote:
> Howdy Chris,
> Can you explain a little more about how QGIS is "not finding coordinates
> on rasters" ? What/which tool are you using to collect coordinates? What
> format of raster are you using and what projection is it in?
> **Note that on the fly projection is not supported for rasters.
Never had this issue before. So this one is new for me. Installed 0.11.0 from
the download page on a fresh install of ubuntu 8.04 Loading NOAA rasters
which have worked seemlessly in the past, all I can do is load the raster and
move it on the screen, I cannot zone or use any of the other features
associated with that tool set.(the one with the blue hand) Looking at the
terminal output I get
"Warning: No valid projection. Unable to set map units"
but I also get this at boottime when I boot from a terminal. As Ive seen this
before and ignored it as the application worked fine. However on this latest
install when loading an NOAA raster I get the following in the terminal
Warning: Creating Warped VRT.
Warning: No valid projection. Unable to set map units.
OK..so I build it from source (stable) and build the test suite as well. I
understand the test suite is not current but shows the above error message
identified in the subject.
In not really sure whats going on here as I've not run across this error
before and used qgis for at least several months now on NOAA charts.
WIll check the build to make sure I didnt miss something but thats unlikely
with the detailed Install Notes and ccmake.
/ch
