[Qgis-user] reference raster layers
Bernardo Rossi Doria berrossi at tin.it
Tue Oct 7 11:41:44 PDT 2008
hello michael,
I read about your discussion in the forum.
Then I first imported the georeferenced vector layer provided by the
itaian statistic institute with municipalities borders.
Looking in the metadata (left mouse-properties) I read that the
projection is UTM zone 32. But the  "setting"  project properties does
not show that kind of projection but suggests to set to WGS84.
I "apply" that suggestion and check OTF. But if I look in the
properties of the layer i find that they are still UTM zone 32.
Then I import a  geoTIFF layer and I let ask  for projection but I do
not find in the list the option UTM zone 32 so I set to wgs84.
But still they do not overlap correctly.
Still something wrong.
How can I set the project  with UTM zone 35 pojection
or
how can I chenge the vector layer from UTM projection to WGS84?
Cannot find a solution.
someone can give me more information?
Thank you all.
Bernardo
Il giorno 30/set/08, alle ore 19:50, Michael Neubauer ha scritto:
> Hello Bernando,
> when both, raster and vector layer, use the same projection, they
> should be in
> the right place and in the right position to each other. So you cannot
> just "move" the layers.
> Maybe you should try to change the projection for the whole project.
> So go to
>> settings > project properties > projection and activate "on the fly
> projection" now you could try to change the projection for the whole
> project.
> e.g. just try the UTM coordinates for your zone and see what that
> does.
> But maybe just your maps are not referenced correctly. When you know
> the
> coordinates for one point on your map, you can put the cursor on
> this point
> and check the displayed coordinates at the right bottom of your
> screen.
> Good luck
> Michael
> p.s.: I had problems with the correct reference system at the
> beginning as
> well; see:
> http://forum.qgis.org/viewtopic.php?f=2&t=718&p=1987&hilit=pinquin#p1987
> Am Dienstag 30 September 2008 10:27:56 schrieb Bernardo Rossi Doria:
>> hello,
>> I am new to qgis.
>> Need help
>> I imported successfully a group of raster  GeoTiff layers (Maps)
>> then I imported a referenced vector layer (Map of municipalities
>> borders officially distributed)
>> they are both (raster and vector) with the same projection (WGS84
>> +no_defs) but they have different origins so the do not overlap.
>> How to move the raster layers in the correct scale and/or position?
>> thankyou all
>> bernardo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
