[Qgis-user] unique id in postgis layer
Ľubomír Varga luvar at plaintext.sk
Wed Oct 22 02:29:50 PDT 2008
Hi.
Iam new in using qgis. I have problem to display data from my postgis enabled
database in postgre. I have table with this definition:
CREATE TABLE t_positions
  id bigint NOT NULL,
  "line" geometry
Is it posible to view data from this table vitw bigint id type in qgis?
I have tried view like this:
select id::int4 as id, location from t_position;
qgis ignored type in view. Instead of it it took type from original table,
which is bigint and delivered me this error:
The view 'public.qgis_route' has no column suitable for use as a unique key.
<message>
Qgis requires that the view has a column that can be used as a unique key.
Such a column should be derived from a table column of type int4 and be a
primary key, have a unique constraint on it, or be a PostgreSQL oid column.
To improve performance the column should also be indexed.
The view you selected has the following columns, none of which satisfy the
above conditions:
'id' derives from 'public.t_positions.id' and is not suitable (type is int8
and has a suitable constraint)
'line' derives from 'public.t_positions.line' and is not suitable (type is
geometry and does not have a suitable constraint)
</message>
So simple question: How to display postgis table with bigint key in qgis?
