[Qgis-user] scaling bug?
Borys Jurgiel borys at wolf.most.org.pl
Fri Oct 24 05:41:18 PDT 2008
Wednesday 22 of October 2008 13:29:54 Ľubomír Varga napisał(a):
> What about posibility to set default units globaly, and also to allow
> autodetect feature? (if in first 100 coordinates in input file is no
> coordinate bigger than 360, than it is degrees, else it is default unit =
> meter/feet selected in some autoselect unit dialog)
I was considering it few days ago and now I think it's not the best way. The
unit is strictly related to the used projection, so I see no sense in
pre-selecting the unit. We should pre-select the whole projection instead.
When you start QGIS, a new empty project is created and it's initially
projected always in WGS-84. Then when you load a layer, you can personalize
QGIS's behaviour related to this layer, but you never can set default
projection of new project. So in my opinion this is the point we should
change. I see two solutions:
1) use the 'Global Default Projection' from the Options dialog as initial
   projection of every newly created project
2) provide a skeleton file for newly created project, as it was proposed in
   this topic already
Regards,
B.
