[Qgis-user] Reprojection tool?
John C. Tull john.tull at wildnevada.org
Mon Oct 27 13:27:05 PDT 2008
On Oct 27, 2008, at 6:16 AM, Magnus Homann wrote:
>>> Agustin Lobo skrev:
>>>> Hi!
>>>> Is there anybody working on a reprojection plugin
>>>> (at least for vector data)? I mean saving a new shp
>>>> file with a different projection, not just on the
>>>> fly.
>>> You can select (right-click in legend) "Save as shapefile..." and
>>> the
>>> layer will be saved inr the current project projection (if turned
>>> on).
>> This has not been my experience. "Save as shapefile" saves in the
>> same projection as the original, not in the project projection.
> Correction! It asks for what proejction to save as. Misremembered. :-)
> This was introduced in r9334. I'm not sure if it made it into
> preview 1.
Very nice. I just tested this and it does perform a reproject on save
based on your chosen CRS. Obviously, you need your vector layer to be
correctly assigned its CRS before you perform the save.
John
