[Qgis-user] DXF import
Werner Macho
werner.macho at gmail.com
Wed Oct 8 19:09:54 EDT 2008
Hi!
I think you mean the Dxf2Shp Converter available as a Plugin.
I'm not sure it it is already in Metis but in the new preview1 there it
is surely selectable allthough I've made some strange experiences
especially with 3d-dxf files import.
But it is surely worth a try.
hope this helps
regards
Werner
Justin Fischer wrote:
> Hi list,
> I've read that there is a DXF to Shapefile converter (e.g.,
> http://www.nabble.com/dxf2Shp-plugin-td16357138.html and
> https://trac.osgeo.org/qgis/ticket/1269 ). I have not yet been able to
> find a plugin in Metis on Ubuntu Hardy that will work with DXF files.
> The only workaround I've seen is to use gvSIG, then bring the shapefiles
> to QGIS. Can someone please direct me?
> Thank you,
> Justin
> Qgis-user mailing list
